"Balanced" RCA wall plate input cuts out hard-panned audio
Jan 14, 2011
304
San Francisco, CA
At most of my employer's locations we use RDL D-J2 (D-J2 ‐ Line Input Assembly) or similar wall-mounted inputs for laptop playback through an installed system. According to the manufacturer, the device does the following: "LEFT and RIGHT are combined and balanced through audio transformers configured to reject induced hum." The cable coming out the back of the plate is just a 3-conductor wire.
According to the copy, the summing process inside the device is supposed to combine and balance L & R down to a mono line. In practice this works fine for music produced in the last decade, but anything from the 70s with hard panning (Bohemian Rhapsody, Pinball Wizard) results in almost complete loss of the L signal. I confirmed this by listening to the track with headphones and taking the left cup off of my ear. What I heard through only the right cup was what our system was reproducing.
Is this device just doing a bad job of summing to mono?
Re: "Balanced" RCA wall plate input cuts out hard-panned audio
Perhaps it's faulty...
How are the three wires coming out of it connected?
[edit.. what happens if you send it a L only or R only signal? /edit]
It's three conductors of the same wire. Positive, negative, neutral.
It's not one unit that's faulty because the same thing happened at several locations with the same setup.
The pattern is that if anything is hard-panned to the left, it's basically lost. That seems like bad design.
To restate JR's earlier post, what happens if you take a mono RCA source and move it from L to R? Does Left simply not work?
Mac
Weird, at the moment I'm unable to reproduce the problem at another location. I'll go back to the location where I was shown the issue and report back.
Are you using the same playback device and program material? I've run into some "smart" devices that do odd things with their combo i/o jacks and program material that was ripped by a home user or someone being "creative" that sounded very odd when summed to mono.
I'm interested to learn what you find out. Thanks for posting this.
Daniel,
In line with Tim's comment: some iDevices [did?] switch L & R when the headphones were plugged/unplugged. Though this wouldn't affect physical signal connections, it could cause issues if one side of the track was blank and THAT was the side being sent through the system.
Just a thought.
