Lighting & Electrical
Basic Lighting Trees needed - recommendations?
<blockquote data-quote="Thomas Whitfield" data-source="post: 6740" data-attributes="member: 3807"><p>This is not a fixed install. However, this venue needs some kind of lighting for monthly shows they have in the main dining / ballroom. They have a riser stage. The area is 8' x 24 and the ceiling height is around 10 feet. Typically the shows are 1 to 4 performers on the stage. I thought maybe two lighting trees facing the stage would suffice. I'm the musical person in this operation. I'm not versed in this profession of lighting at all. I do know eventually we will have the lights triggered via DMX plugin in Logic Pro 9. So therefore the lights we get now should be able to accept DMX signals in the future. The lights will be at least 40 feet from the stage. Thank you for your help.</p></blockquote><p></p>
[QUOTE="Thomas Whitfield, post: 6740, member: 3807"] This is not a fixed install. However, this venue needs some kind of lighting for monthly shows they have in the main dining / ballroom. They have a riser stage. The area is 8' x 24 and the ceiling height is around 10 feet. Typically the shows are 1 to 4 performers on the stage. I thought maybe two lighting trees facing the stage would suffice. I'm the musical person in this operation. I'm not versed in this profession of lighting at all. I do know eventually we will have the lights triggered via DMX plugin in Logic Pro 9. So therefore the lights we get now should be able to accept DMX signals in the future. The lights will be at least 40 feet from the stage. Thank you for your help. [/QUOTE]
