Behringer X32, S16, and P16 Question
Dell Smith
I'm sure I'm just a complete moron (or really tired), but I have a question regarding setup.
We installed this system today, and we have a mixture of inputs going through the S16 and inputs going directly into the X32. The ULTRANET connection to the P16-D (and, subsequently, the P16-Ms) comes from the S16. We get sound and personal monitoring no problem from the channels plugged into the S16, but we cannot figure out how to route channels to the P16s that are plugged directly into the X32. What am I missing, here?
We did successfully get a line from the X32 to the P16 by running an ethernet cable from the ULTRANET port on the X32 to the P16-D, but that doesn't seem like it should be necessary. Like I said, I'm probably overlooking something silly, but I cannot figure this out. Thanks for any help you can provide!
Dell
Re: Behringer X32, S16, and P16 Question
What you get from the S16 depends on what mode it is set to.
If you have it in mode 1, 2 or 3, the ultranet output will be what is routed to p16 out on the console providing the aes50 routing has p16 routed to output 33-48
