Hi!
First post alert... Apologies for cutting to the chase!
I've bought a pair of secondhand Martin Audio S18+ subs:
https://martin-audio.com/downloads/datasheets/s18+datasheet.pdf
TYPE Compact, vented sub-bass system
FREQUENCY RESPONSE (1) 40Hz-120Hz ± 3dB
-10dB @ 35Hz
DRIVERS 18” (460mm)/4” (100mm) voice coil LF driver
RATED POWER (2) 750W AES, 3000W peak
RECOMMENDED AMPLIFIER MA9.6K
SENSITIVITY (3) 102dB (half space)
MAXIMUM SPL (9) 130.5dB continuous, 136.5dB peak (half space)
NOMINAL IMPEDANCE 8 ohms
The rest of my system (HK Audio / db Technologies) is powered so this is my first venture into the world of independent amplification!
I understand the basic principles of ohms, watts and the like, and have been trying to research amps at the budget end of the scale that will do the job.
I know Behringer is still a relatively dirty word in the pro-PA world but here are the options / approximate prices that I've found so far. Bear in mind that the choices / availability are limited as I'm based in Dubai.
Behringer NU3000 (Assume 2 required) @ 1000AED ($270) each
https://www.music-group.com/Categories/Behringer/Power-Amplifiers/Portable-Amplifiers/NU3000/p/P0B1P
Behringer EP4000 (Maybe 2 required?) @ 1500AED ($408) each
https://www.music-group.com/Categories/Behringer/Power-Amplifiers/Portable-Amplifiers/EP4000/p/P0A37
QSC GXD 8 @ 3000AED ($815)
https://www.qsc.com/live-sound/products/power-amplifiers/gxd-series/gxd8/
Behringer NU12000DSP @ 3200AED ($870)
https://www.bhphotovideo.com/c/prod...u12000dsp_ultra_lightweight_high_density.html
My aim is to get the best suited amp(s) for the money. If I understand the basic phsyics well enough then I need a genuine 1500W per channel at 8 ohms, be that bridged or otherwise. Am I correct in saying that a single 3000W bridged amp at 4ohms would also suffice if the speakers were wired in parallel? I'm also concerned that the NU12000DSP will require a high amp electrical circuit which my regular venue will not be able to supply. Is two NU3000 in bridged mono an option? That would give 1250W at 8 ohms on both sides.
All advice much appreciated!
Cheers,
Tim
-10dB @ 35Hz
Cheers,
Tim
