I'm doing a show outdoors friday for a benefit that has a stage approx 32' wide by 16' deep and 18" high. I've got a pair of front loaded double 18's and a pair of jbl 4731's with 60x40 horns instead of the stock 90 degree horns. The crowd size is approx 200. The area to be covered is about 90' wide x 80' deep.
My options are to stage stack the speakers 1 over 1 on stage. Ground stack 1 over 1. Or ground stack the subs and put the tops on the stage. Should I consider putting the subs together in the center? Or will this cause too much bass on stage? What would you do? The subs are approx 43H x 24W x 24D.
