Located in Biloxi, MS
Single space, three channel mic/line mixer
Biamp Professional Audio Systems - 301 and 601 Mixers
Sell if off for $200.00 (48 State delivery included)
The 301 is a single rack space, three input mic/line mixers. Each input channel uses a differentially balanced, discrete transistor mic/line preamplifier for low noise and low distortion performance. Inputs are provided to accept signals from microphones and/or line level devices. Special features, including limiters and remote level control, make the 301 extremely versatile. 301 mixers are dependable, easy to install, simple to operate, and are covered by Biamp Systems' five-year warranty.
FEATURES
three electronic balanced mic/line input channels (301)
30dB rear panel Pad switch on each input channel
40dB screwdriver-adjust Trim on each input channel
+10dB Peak LED indicator on each input channel
rotary level control on each input channel
auto-muting of one channel for "talk-over" applications
+24 volt Phantom Power assign switch on each input
electronic balanced main output with rotary level control
remote control of main level from up to 2000 feet away
main patch insert point for external processing devices
main stacking input accepts signals from other mixers
screwdriver-adjust tone controls & limiter on main output
-20dB Signal Present LED indicator for main output
all input/output/control on plug-in barrier strip connectors
CE marked and UL / C-UL listed power source
FEATURES
