Selling off some of my DSP units
Located in Biloxi, MS
Biamp Nexia TC
Biamp Professional Audio Systems - Nexia TC
Dealer cost is nearly $1800.00
Sell for $900.00 with 48 State delivery included
An example:
http://c353616.r16.cf1.rackcdn.com/2-3_(Court_-_NexiaTC,VCB).pdf
8 wide-band AEC balanced mic/line inputs
2 standard balanced mic/line inputs
4 balanced mic/line outputs
Nexia TC is a digital signal processor featuring Biamp Sona™ AEC — our proprietary wideband acoustic echo cancellation algorithm. Designed specifically to provide crisp, clear audio in teleconferencing applications, Nexia TC delivers true 20Hz to 20kHz bandwidth during multiple participant conversations, with natural, true-to-life sound and full duplex transmission of speech, including doubletalk. Sona™ AEC also delivers increased tolerance to differing signal levels, plus faster installation and setup.
Nexia TC includes a broad selection of audio components, routing options, and signal processing. The internal system design is completely user definable via PC software, and can be controlled via dedicated software screens, RS-232 control systems, and a variety of optional remote controls. Multi-unit Nexia systems can be created utilizing Ethernet and NexLink.
FEATURES
telephone interface with line & set connections
Ethernet port for software configuration/control
serial port for third-party RS-232 remote control
remote control bus for dedicated control panels
NexLink ports for multi-unit system designs
Nexia software for Windows® 2000/XP Professional
pre-configured I/O with definable processing
RoHS compliance and AES grounding practices
CE marked and UL listed
covered by Biamp Systems' five-year warranty
Ability to select, view, and calibrate: Mixers, Equalizers, Filters, Crossovers, Dynamics, Routers, Delays, Controls, Meters, Generators, Diagnostics.
Telephone Interface capabilities include:
initiation of outgoing calls
detection and answering of incoming calls
line echo cancellation
TouchTone™ decoding
caller ID reception
call progress detection
line intrusion detection
continuous line status and fault monitoring
Check out the software here:
http://c353616.r16.cf1.rackcdn.com/NexiaSetup3.3.exe
Biamp Nexia TC
An example:
FEATURES
TouchTone™ decoding
caller ID reception
