[FS] big console case, must go!
This is the original case that my M7CL-48 came in. As you can see it's just your basic imported OSP brand case. It will fit a Yamaha M7CL-48 with no meter bridge or any similar size console.It would also be great for building some compartments and fitting a ton of LED par fixtures in for a nice lighting package. It has some T-nuts installed for mounting a caster board and will need a little bit of work, but it's reasonably solid and not beat up.
I can barely walk in my shop so it really needs to go. Local pickup in northern Delaware would be preferred, just minutes off of I-95. I travel a lot so I may be able to drop it off in the region as well if it's on my way. Any takers at $40?
