Re: BNC crimp tool
Not to revive a zombie thread, but to clarify for future readers:
What tooling you use will depend on what cable and signals you are running.
For cases where standard RG-6 Quad shield will suffice (analog SD/HD and/or 75Ohm cable networks) then "generic" tools and compression connectors are just fine.
When we get into the realm of high speed digital interconnects then we generally will need to get all matchy-matchy. In this venue, we need to match our cable to our formats, connectors to our cable, and our tools to both our connectors and cable in order to get long-term trouble-free performance.
Philip above mentioned a Canare example.
Another example would be using Belden 1694a with Kings 2065-10-9 connectors, KTH-1000 crimp frame with a KTH-2255 die, Paladin CSTPro Stripping frame with a 2247 orange cassette and a Paladin 89413 flare tool. Oh, and a strain relief compatible with that whole mess.
This gets really complicated when you have multiple cable and connector types. At last count I probably have 1000$+ in Coax tooling, but it is what it is. I recommend you make informed decisions up front and then plan to stick with your cable/connector selections as long as practical.
One notable exception to all this is the ex-ICM DoubleBubble system, now owned by Belden and marketed as the "Belden Brilliance Video Connector".
This is the first notable attempt at establishing a standard compression style system for high-speed digital interconnects. With an adjustable strip tool and the compression frame you can do anything from RG6Q with an RCA connector to an ultraflexible RG59 with BNC inside the same toolset.
I have purchased toolsets and sample connector lots for this product but have yet to form a full opinion on it.
Hope this may help someone searching later.
Karl P
