Lighting & Electrical
Breaker Panel Tie-in... What is the CORRECT way to pull power?
<blockquote data-quote="Matt Vivlamore" data-source="post: 1397" data-attributes="member: 33"><p>When you are tieing power into a Breaker Panel, how do you pull power off the panel and to your Distro?</p><p></p><p>What is the CORRECT way of doing this?</p><p></p><p>Now that I have the 4/4 power cable, I can tie into the breaker panel directly (if I needed to). Most of my venues have a 14-50 Range Plug on the wall availble.</p></blockquote><p></p>
[QUOTE="Matt Vivlamore, post: 1397, member: 33"] When you are tieing power into a Breaker Panel, how do you pull power off the panel and to your Distro? What is the CORRECT way of doing this? Now that I have the 4/4 power cable, I can tie into the breaker panel directly (if I needed to). Most of my venues have a 14-50 Range Plug on the wall availble. [/QUOTE]
