Not very good with the difference between cat 6 and cat5. Does anyone know if you can use Cat6 to connect the pro 2 surface to the stage box? Midas says use cat5, but doesn't say cat 6 can not be used. Thanks in advance!
My impression is that the only difference is that Cat 6 is one gauge thicker wire.
Can anyone confirm or deny this?
This is not an appropriate forum for advise relating to hard engineering. Nothing in this thread so far is a passable explanation and most of it is totally wrong.
I think it's really funny when people have spelling errors in their condescending messages.This is not an appropriate forum for advise relating to hard engineering. Nothing in this thread so far is a passable explanation and most of it is totally wrong.
I don't have time to explain every difference between the two categories.
there are several parameters which change:
[TABLE="width: 100%"]
[TR]
[TD="bgcolor: #f1f1f1"]Parameter[/TD]
[TD="bgcolor: #f1f1f1"]Category 5
and Class D
with additional
requirements TSB95
and FDAM 2[/TD]
[TD="bgcolor: #f1f1f1"]Category 5e
('568-A-5)[/TD]
Category 6
Class E
(Performance at
250 MHz shown
in parentheses)[/TD]
[/TR]
[TR]
[TD]Specified frequency range[/TD]
[TD="align: center"]1-100 MHz[/TD]
[TD="align: center"]1-250 MHz[/TD]
[/TR]
[TR]
[TD]Attenuation[/TD]
[TD="align: center"]24 dB[/TD]
[TD="align: center"]21.7 dB
(36 dB)[/TD]
[/TR]
[TR]
[TD]NEXT[/TD]
[TD="align: center"]27.1 dB[/TD]
[TD="align: center"]30.1 dB[/TD]
[TD="align: center"]39.9 dB
(33.1 dB)[/TD]
[/TR]
[TR]
[TD]Power-sum NEXT[/TD]
[TD="align: center"]N/A*[/TD]
[TD="align: center"]37.1 dB
(30.2 dB)[/TD]
[/TR]
[TR]
[TD]ACR[/TD]
[TD="align: center"]3.1 dB[/TD]
[TD="align: center"]6.1 dB[/TD]
[TD="align: center"]18.2 dB
(-2.9 dB)[/TD]
[/TR]
[TR]
[TD]Power-sum ACR[/TD]
[TD="align: center"]N/A[/TD]
[TD="align: center"]15.4 dB
(-5.8 dB)[/TD]
[/TR]
[TR]
[TD]ELFEXT[/TD]
[TD="align: center"]17 dB
(new requirement)[/TD]
[TD="align: center"]17.4 dB[/TD]
[TD="align: center"]23.2 dB
(15.3 dB)[/TD]
[/TR]
[TR]
[TD]Power-sum ELFEXT[/TD]
[TD="align: center"]14.4 dB
[TD="align: center"]14.4 dB[/TD]
[TD="align: center"]20.2 dB
(12.3 dB)[/TD]
[/TR]
[TR]
[TD]Return loss[/TD]
[TD="align: center"]8 dB*
[TD="align: center"]10 dB[/TD]
[TD="align: center"]12 dB
(8 dB)[/TD]
[/TR]
[TR]
[TD]Propagation delay[/TD]
[TD="align: center"]548 nsec[/TD]
(546 nsec)[/TD]
[/TR]
[TR]
[TD]Delay skew[/TD]
[TD="align: center"]50 nsec[/TD]
[/TD]
[/TR]
[/TABLE]
You cannot simply change cat 5 for cat 6 in an analog device or your device will not work anymore, especially if you are transmitting video or another high frequency signal. This is because the skew changes and the rx equipment cannot compensate for this change. Digital devices are incredibly more picky about which cable specification is used.
[TR]
and Class D
with additional
requirements TSB95
and FDAM 2[/TD]
('568-A-5)[/TD]
Category 6
Class E
(Performance at
250 MHz shown
[/TR]
[TR]
[/TR]
[TR]
(36 dB)[/TD]
[/TR]
[TR]
[TD]NEXT[/TD]
(33.1 dB)[/TD]
[/TR]
[TR]
(30.2 dB)[/TD]
[/TR]
[TR]
[TD]ACR[/TD]
(-2.9 dB)[/TD]
[/TR]
[TR]
(-5.8 dB)[/TD]
[/TR]
[TR]
[TD]ELFEXT[/TD]
(15.3 dB)[/TD]
[/TR]
[TR]
(12.3 dB)[/TD]
[/TR]
[TR]
(8 dB)[/TD]
[/TR]
[TR]
(546 nsec)[/TD]
[/TR]
[TR]
[TD]Delay skew[/TD]
[/TD]
[/TR]
[/TABLE]
