Junior Varsity
Ceiling Speakers vs. 360 Speaker vs. wall mounted speakers
<blockquote data-quote="Kevin Maxwell" data-source="post: 208000" data-attributes="member: 321"><p>Keep in mind that when someone mentions ceiling speakers there are all sorts of different ones. What you are doing might cost more to do with ceiling speakers if you use the right ones for the application. You don’t want the cheap ones at all. Also depending on if there are other tenants in the building above you, if you use ceiling speakers you will most likely need the type that are fully enclosed to limit the amount of sound that goes up to the next floor above you. If the room has a suspended ceiling the installation of ceiling speakers is much easier than if it is a solid ceiling. There are a lot of factors that come into play in doing this properly.</p></blockquote><p></p>
[QUOTE="Kevin Maxwell, post: 208000, member: 321"] Keep in mind that when someone mentions ceiling speakers there are all sorts of different ones. What you are doing might cost more to do with ceiling speakers if you use the right ones for the application. You don’t want the cheap ones at all. Also depending on if there are other tenants in the building above you, if you use ceiling speakers you will most likely need the type that are fully enclosed to limit the amount of sound that goes up to the next floor above you. If the room has a suspended ceiling the installation of ceiling speakers is much easier than if it is a solid ceiling. There are a lot of factors that come into play in doing this properly. [/QUOTE]
Junior Varsity
