Coming to a stage near you: Acoustiblok
Re: Coming to a stage near you: Acoustiblok
I have a product that eliminates 100% of the noise.
Nice work. Very Road Runner / Coyote. The original solution was more Spinal Tap-esque. A cross between the plastic cocoon thing that wouldn't open and the 'monolith' that was lowered to the stage. But the anvil could result in blood and guts in the wedges. And a hole in the stage.
I love how the 2 guys holding the ropes (off to the sides) have hard hats on, but the guy standing under the suspended load does not :)
Jason
At least those 2 guys had hearing protectors on their hard hats.
The situation is not quite as extreme as they would have it appear to be. The 130 dB seems to be at the mic located about 6" in front of the speaker stack, not at the listeners' ears. That would be about 94 dB at 32 feet (6 doublings of the distance, 36 dB down from 130), approximately where the listeners were located. That is not abnormally loud for a rock guitar. Also, it is curious that when the box was lowered, the SPL inside did not increase due to the sound that was now reflected back to the source. Massive limp membrane like Acoustiblok does reflect mid and high frequencies fairly well. The box did apparently decrease the SPL at the listeners' ears by over 30 dB so it was below the background SPL, a respectable reduction, but the box was made of 2 layers of Acoustiblok plus an airspace filled with fiberglass insulation, not a single layer of Acoustiblok. Massive limp membranes have been used in this way in acoustics for many years, so this is a useful marketing approach but not as magical as they would have us believe.
Yep. Sheet lead is the most common massive limp membrane material, and is good for approximately 20dB or attenuation
You can hear variation of this on say a Stageline or similar stage where the fabric isn't taught all the higher frequency stuff disappears behind or to the sides some of the bigger units even attenute quite low frequencies. G
There's similar material (massive limp membrane backed by foam) that some other people in my PhD lab used to acoustically isolate an optical interferometer setup from acoustic noise in the room. I've also used it quite successfully between components and the optical table to block vibrations in things like shutters from being conducted to other components.
I don't really miss the tunable diode laser that doubled as a pretty effective microphone, let me tell you.
Interesting to note that one pound of lead per square foot has much more LF attenuation (at least in the 160 Hz range), while one pound of Acoustiblock per square foot appears to have more HF attenuation.
Be interesting to see the results of both compared under identical test circumstances.
