CROWN I-Tech 4x3500HD DriveCore
warren noronha
3
Can anyone guide me on the performance of the Crown I-Tech 4x3500HD Amplifier ?
I would probably use it on my JBL SRX or STX subs + VRX 932 LA Tops.....anywhere between 2 - 4 Ohms....
Warren
Re: CROWN I-Tech 4x3500HD DriveCore
Warren
it is a top tier tour-grade amp with full V5 manufacturer preset support. It will work great for your system. The only challenge you may have is running it hard may blow the breaker if you are on 120v power, whereas two 2-channel amps could be split to two circuits.
Thanks TJ
