CS6364 Wiring
Sep 12, 2012
654
6
SW Ontario
Bought a few Hubbell CS6364 to make Nema 14-50P to CS adapters, the CS connector is labeled W, X and Y inside.
I assume that standard procedure is that W is wired to neutral and hots are wired to X and Y, can anyone confirm?
Re: CS6364 Wiring
If I'm not mistaken, W stands for "white", the standard color for neutral. If in doubt, I just find the Nema chart online and use a meter to confirm the wiring of the pins.
Re: CS6364 Wiring
Yep. If there is a third phase, that would be Z. Conveniently green and ground both start with a "G" so no confusion there.
Re: CS6364 Wiring
Yep. And if those connectors follow industry convention, your ground terminal should have a green screw, the neutral (labeled W) should be a nickle (silver) terminal, and the line conductors should be brass (gold) terminals.
Re: CS6364 Wiring
And to add to what everyone else said, in the CD636x series of connectors, the two prongs with the wing on them are the hots.
