OK Bennet-now you have gone and messed things up.
Why do you make me go and THINK! and question things. Everything was nice and happy until you just had to go and compare DSP's now didn't you!
And you think you want to get data on the differences between DSP's. Well how about the differences between measurement platforms-HUH What about THAT for a project
Kemper Watson is bringing over a couple of his DBX DSP's for me to measure and give you the data.
So to get ready I setup my Smaart rig and did something stupid. I did a loopback test. Yeah I know-why do something stupid like that
I am using a Motu8pre as my interface.
I have done loopback tests with this unit before on Systune and all was fine, but never bothered to do it with Smaart V7. I just ''assumed'' it was correct. You know what happens when you do that now don't you.
So anyway I am getting an odd freq response. It is flat up to about 2KHz and then starts a rise of 1.5dB at 18Khz.
So my first thought is that the interface is not flat
. So I did a loopback test using Systune-without touching anything on the interface or setup and it is flat to 20Khz.
I went back to Smaart and it was still off.
But that is not all. Systunes phase response is around 2° with a 30° rise at 18Khz.
Smaart V7s phase response is around -178° with a 30° rise at 18Khz.
So the shape is the same-but they are out of polarity.
As the old saying goes- a Man with a meter is sure-A man with 2 meters is sure of nothing.
So what is correct?
Yes I have already posted a question to Rational.
So realize that the curves I will be sending you will have a slight error on the top end-that is not a result of the DSP settings.
So take that data and - well do whatever you want with it
Just adding to the confusion.
Why does this stuff keep getting harder and more mysterious? Is anything real? Where's my RTA and I will call it a day.
So what is correct?
