Re: Darwin install award goes to....
I am not defending #3, but in many cases there is no way to get a man lift into the room. Maybe a single Genie-but not one for 2 people.
Yes there are a number of things wrong and not safe.
But since the video got posted-I would assume nobody got hurt.
Yup. Having worked in plenty of old churches, rarely are you able to get a real lift in. Stairs are an effective barrier against using lifts. Except the new track-based
JLG zoomer. Envious. So envious.
Even if you could, it's highly unlikely the floor could support it. A single-man able to reach this height weighs 1,000#. Add 300# of man and gear, then lean forward...and that's a lot of weight on a very small surface area. And frankly, this is more stable than a single-man at full extension. Good Lord, those things are scary. Not sure how effective the outriggers they're using here are at that height, though.
Safety rails are nice, in theory...but they don't always fit. In this case, the 1/2-scaff top portion barely fits under the proscenium; railings certainly would not. So the 1/2-scaff serves as a sort of safety-railing. Why is it missing a crossbrace? No idea. Probably forgot it at the shop. Not defending; just explaining.
Scariest part? When they moved and re-used the 2nd highest platform. Seriously. Get some more platforms. And a friggin' rope...watching that guy build that tired ME out.
Also...where did that 2nd platform go? They put it in, then took it out? Why? Oh, right...they needed it to get the rig up, PLATFORM BY PLATFORM. Seriously. ROPE.
If you haven't spent a lot of time on scaff, I can understand how this could frighten you. But once you get used to it, it's really not that bad. That being said...this is a little extreme.
