I am the original owner ... unit is very clean used and has lived in a rack since new... I have had unit 6 or 7 years...updated to latest firmware... works perfectly...has been sitting in a rack on shelf and has seen limited used over the years of owning... this is too expensive to sit around unused....I will wipe the dust off. Very nice unit !
Unit is used... no warranty but works perfectly..... $1750 plus shipping
for those who don't know i will post some specs below
4 inputs by 8 outputs
48 and 96 kHz operation
Color QVGA Display
4 analog and AES/EBU inputs
8 analog and AES/EBU outputs
Full Bandpass Filter, Crossover and Routing Configurations with Bessel, Butterworth, and Linkwitz-Riley filters
31-Band Graphic and 9-band Parametric EQ on every input
6-band Parametric EQ on every output
Loudspeaker Cluster and driver Alignment Delays
Selectable DSP inserts on all inputs and outputs including Classic dbx Compression, Limiting and Advanced Feedback Suppression among others
Ethernet HiQnet™ networking control
dbx ZC wall panel control
Color QVGA Display
