Hi there,
just bought a used yamaha MY16-es64 with a MY16-EX.
I wanted to test them in my LS9-32. When i check in the slot setup i see in slot 2 the MY16-EX but nothing in slot 1 where my MY16-es64 is plugged... The LS9 give a sync error too on the MY16-EX card... In this setup is it the LS9 that is the clock master??
Try to see the card via Auvitran AVS-Monitor and nothing there too...
It is possible to check the card without SB168?? (I buy them later)
When i plug the MY16-es64 to my laptop via the ethersound input cat5 connector on the card my laptop connect to the card via my ethernet card. (i see that the ethernet part of the card is working because it show limited network)
When the card is not connected to a SB168 it is normal that no TX/RX LED blink?
LS9 firmware : 1.33
AVS-Control panel: 4.2.8.264
MY16-es64 firmware : unknow... (where i can see that??)
Thanks a lot for your advice!
Fred
LS9 firmware : 1.33
Fred
