How hard is it to do a firmware update on an SD9? We have one that we aquired from another company and the firmware is old, it doesn't even recognize the latest offline editor files.
TIA
TIA
Not very hard if you follow the instructions, but you need to speak to the national distributor to get the files. Takes ½ hour max.How hard is it to do a firmware update on an SD9? We have one that we aquired from another company and the firmware is old, it doesn't even recognize the latest offline editor files.
TIA
That doesn't seem like a very wise approach to customer service. I mean, what are you going to do, load up Digico's firmware on a Behringer console? What exactly are they trying to protect here?
And, btw, is it just me or does Digico's offline editor pretty much suck?
You can ask some of the lighting console manufactures about that, cloned consoles running the original software...
Not the same thing. All a lighting console does is control on/off and fade up/down times and give you a pretty GUI to look at. They are all just basically big spread sheets. Sound consoles handle the actual analog to digital to analog conversion and way, way more processing than a lighting console. For a lighting console to be viewed the same as a sound console, it would have to contain all of the dimmers, dimmer processing units, and all of the CPU functions for the moving lights inside the console as well.
Hi Steve, which version is the console running ? If it's too old I think you must upgrade to previous versions before coming to V573, released 1 week ago.
Yes, if the console is running firmware which is older than V443 you need to upgrade to that first, then upgrade again to the latest (currently V573). If you try and skip this step it will just crash, which happened to me on an SD11. I believe it's something to do with replacing ReadyOn, which is involved in making a snapshot of the Windows environment, with something new.Hi Steve, which version is the console running ? If it's too old I think you must upgrade to previous versions before coming to V573, released 1 week ago.
