We have an SD9 that was not shut down “properly” recently. The console powered back on and is fully functional.
It is installed at a performance space and the main tech’s method for each show is to piggy back all new sessions from the previous show session instead of using a template. They are adamant that the board is buggy and is in a constant state of almost failing, however it never does.
Has anyone ever experienced a Digico SD not coming back after a power cut off or improper shutdown?
We toured for years with an SD12 at foh and SD9 at monitors. Never had any problems whatsoever. The boards lived in trailers for months of constant use. I’m beginning to think that the main issue is that the PA routing is unclear and the only way to ensure that everything works for a show is to use the previous session.
If something happens to this session, the tech would not be able to set up the board again for a show.
Would love to hear from DigiCo users about reliability and best practices. Is it really possible to break one of these things by not doing the shut down sequence? What is actually happening during shut down? The venue should probably be using a template correct?
