Re: DM2000 "VCA's"
I'm trying to understand (from the manual, with out a console in front of me) how the "VCA's" on a DM2000 work. I say "VCA" as from what I've read the DM2000 doesn't have real VCA's or DCA like the M7CL with which I'm familiar and that the fader groups can be tasked to work like a VCA/DCA.
I'm not clear however on what limitations this imposes?
- Does using "VCA's" cut into the 8 audio sub groups? (I think the answer is no)
- Does using "VCA's" cut into the number of channels that can be linked?
Is there anything else I should be aware of?
Thanks
Philip
Hello Philip.
Yamaha's DM/0-style mixers' way of doing things have benefits and disadvantages.
If you go to the group menu you can assign output faders or input faders to eachother (not inputs and outputs combined in one group). What happens then is that by moving one fader you physically move the rest of the faders in that group and all the feeds from every one of the channels in the group are affected just like if you had moved every one of those faders by hand at the same time. Since any VCA basically remote controls fader outputs this makes perfect sense to me. One disadvantage is that you can only put a channel in one group at the time. If you hold SEL while moving one fader in a group you can temporarily "release" it from the group and hence move it on it's own.
If you additionally link all the faders in one group in a EQ group and/or a comp group, changing the EQ or comp on one channel will affect all other channels' EQ and comp in the same way effectivlely giving you EQ and comp on a VCA much like you already know from your BUSes. You can switch the EQ/comp link on after you have set your channels individually so you still have individual control from the start. If you need to change one channel EQ/comp individually mid-show it's a little more complicated as you'll need to switch off the EQ/comp link temporarily while you make the adjustment. There are several ways of doing this, including putting a link group on/off master switch on a UDK.
No, grouping does not affect your ability to also use BUSes exactly like you are used to. It's just an addition just like you might have both VCAs and audio groups on an analog mixer.
If you have paired two channels as a stereo pair there is no way to individually assign them to a fader/EQ/comp group. If you assign one the other follows.
Another cool use for groups is that instead of making the usual stereo pair you can assign just two channels to a fader group and an EQ group making it act as a stereo pair with just one important difference: Now you can send just the left keyboard channel to the left key wedge and just the right channel to the right key wedge. There is no way to do this with a normal stereo pair as all settings are copied from one channel to the other when you make the stereo pair, and all AUX adjustments from there on are equal for both sides of the stereo pair.
If you like to use the remote layer as a user assignable layer you can put your entire drum kit on a group and just stick one drum channel on the user assignable layer, saving available faders for other things. If you move that one drum channel the rest of the drum channels will track even if you don't see it visually in front of you. Of course, if you do this, and need to adjust the snare, you'll need to flip to the layer that has the drum channels on it and press SEL while you move the snare fader(s).
Another cool use for groups is to link output faders. You can make your AUX subwoofer output track the main master autmatically along with things like delay speakers or front fills run through the matrixes, or you can make it possible to adjust all AUX masters at once.
Best regards,
Kristian
