Junior Varsity
Do I really need a Nexo NXamp 4x1?
<blockquote data-quote="Craig Morgan" data-source="post: 7331" data-attributes="member: 2339"><p>Hi, I have a Nexo system 4 x PS8's (8ohm) and 2 LS400 (6ohm) subs with a controller.</p><p></p><p>I want a stereo system 2 tops 1 sub each side and need 1 amp if possible to power it all correctly.</p><p></p><p>I think the PS8 requires 500w each and the subs 700w, I'm not sure on the ohms when using all together, if someone can shine light on that.</p><p></p><p>Nexo have recommended I go with their NXamp4x1, these seem very expensive and because I already have a controller I'm wondering if I need that particular amp?</p><p></p><p>Could I use a 4 channel amp, decent quality and what is out there for me to buy?</p><p></p><p>Thanks</p><p>Craig</p></blockquote><p></p>
[QUOTE="Craig Morgan, post: 7331, member: 2339"] Hi, I have a Nexo system 4 x PS8's (8ohm) and 2 LS400 (6ohm) subs with a controller. I want a stereo system 2 tops 1 sub each side and need 1 amp if possible to power it all correctly. I think the PS8 requires 500w each and the subs 700w, I'm not sure on the ohms when using all together, if someone can shine light on that. Nexo have recommended I go with their NXamp4x1, these seem very expensive and because I already have a controller I'm wondering if I need that particular amp? Could I use a 4 channel amp, decent quality and what is out there for me to buy? Thanks Craig [/QUOTE]
Junior Varsity
