Junior Varsity
Dual PA speaker deployment
<blockquote data-quote="Dick Rees" data-source="post: 2324" data-attributes="member: 16"><p>I've got a Jazz Fest coming up in September where I want to run a "dual PA" setup. I'll have scaffolding with a deck a bit over 6' in the air, subs underneath and behind some scrim. Here's the setup:</p><p></p><p>PA #1: 4 x EV T251+ over 4 EV Sb180, 2 & 2 per side.</p><p></p><p>PA #2: 2 x QSC KW 152, 1 per side.</p><p></p><p>Delays: 2 x QSC K10, 10' behind the mix position.</p><p></p><p>Location is in the street between two x 2 story brick buildings, approx. 90' width, depth is 60' from stage to FOH, FOH located approx. 35' in from the intersection (where we lose containment from the buildings on either side.</p><p></p><p>I'll wire it up and feed it so that the keys, bass. backing vocals and kit mics (except for the overheads) are in PA #1, PA #2 carrying the sax, drum OH and lead vox.</p><p></p><p>The question is this:</p><p></p><p>What is the optimum deployment of the PA1 and PA2 cabinets? I'd like to just put the QSC's in the "solo PA" on top of the properly splayed EV's, but am concerned that I'll be shooting over the heads of the people in front. I can put them three wide with the solo PA cabs towards the insides or put the solo PA cabs between the EV's of PA #1 (which arrangement seems to me to not really be desirable). </p><p></p><p>Thanks.</p><p></p><p>DR</p></blockquote><p></p>
[QUOTE="Dick Rees, post: 2324, member: 16"] I've got a Jazz Fest coming up in September where I want to run a "dual PA" setup. I'll have scaffolding with a deck a bit over 6' in the air, subs underneath and behind some scrim. Here's the setup: PA #1: 4 x EV T251+ over 4 EV Sb180, 2 & 2 per side. PA #2: 2 x QSC KW 152, 1 per side. Delays: 2 x QSC K10, 10' behind the mix position. Location is in the street between two x 2 story brick buildings, approx. 90' width, depth is 60' from stage to FOH, FOH located approx. 35' in from the intersection (where we lose containment from the buildings on either side. I'll wire it up and feed it so that the keys, bass. backing vocals and kit mics (except for the overheads) are in PA #1, PA #2 carrying the sax, drum OH and lead vox. The question is this: What is the optimum deployment of the PA1 and PA2 cabinets? I'd like to just put the QSC's in the "solo PA" on top of the properly splayed EV's, but am concerned that I'll be shooting over the heads of the people in front. I can put them three wide with the solo PA cabs towards the insides or put the solo PA cabs between the EV's of PA #1 (which arrangement seems to me to not really be desirable). Thanks. DR [/QUOTE]
Junior Varsity
