Junior Varsity
EDM Shows
<blockquote data-quote="Ben Lagman" data-source="post: 7761" data-attributes="member: 85"><p>When doing EDM shows, I've always been curious as of to how simple they are (unless I'm mistaken). Since the DJ is using his backline mixing his tracks, as well as having the tracks going to his own mixer, does his mixer's output go directly to the board at FOH through a compressor, to the mains? Because if I'm not mistaken, that'd be only 2 channels, plus the DJ's microphone along with maybe a very select few other channels for anything else. Comparing it to when a band plays a venue utilizing countless channels with different effects going through each, etc., are EDM shows much easier? Many of the EDM shows I've attended seem to only utilize about 2-4 channels in total as well when I look over at the board at FOH while they're going on...</p></blockquote><p></p>
[QUOTE="Ben Lagman, post: 7761, member: 85"] When doing EDM shows, I've always been curious as of to how simple they are (unless I'm mistaken). Since the DJ is using his backline mixing his tracks, as well as having the tracks going to his own mixer, does his mixer's output go directly to the board at FOH through a compressor, to the mains? Because if I'm not mistaken, that'd be only 2 channels, plus the DJ's microphone along with maybe a very select few other channels for anything else. Comparing it to when a band plays a venue utilizing countless channels with different effects going through each, etc., are EDM shows much easier? Many of the EDM shows I've attended seem to only utilize about 2-4 channels in total as well when I look over at the board at FOH while they're going on... [/QUOTE]
Junior Varsity
EDM Shows
