DIY Audio
Eighteensound 18LW2600
<blockquote data-quote="Carl Klinkenborg" data-source="post: 219040" data-attributes="member: 12770"><p>It shouldn't sound desperately different. As a horn enclosure the usual qualities of high efficiency, no low bass (singly), peaky response, and poor transient decay will remain.</p><p>You might even gain a tad more LF due to the lower Qts and higher EBP of the 2600! </p><p>Vas is near-identical so rear volume will be compatible.</p></blockquote><p></p>
[QUOTE="Carl Klinkenborg, post: 219040, member: 12770"] It shouldn't sound desperately different. As a horn enclosure the usual qualities of high efficiency, no low bass (singly), peaky response, and poor transient decay will remain. You might even gain a tad more LF due to the lower Qts and higher EBP of the 2600! Vas is near-identical so rear volume will be compatible. [/QUOTE]
DIY Audio
