The band I work with the guitarist uses a Line6 SpiderValve MKII and there is a XLR Direct Out on the back of the amp. Well I am trying to use that and every time I plug and XLR into it, I get a nasty buzz in the Mixer and out of his Guitar amp even when we 'Lift" the ground. As soon as I remove the XLR, no more buzz. The best way I have been able clean it up is to run out of the PreAmp Out using a 1/4"-TS cable into an Active DI and even then there is still some buzz and it increases with his guitar volume in the mixer, but not out of his speaker.
What can I use to eliminate the BUZZ between this guitar and my Mixer?
Mixer and Line6 on same outlet and All Ground plugs accounted for.
