[FS] Eminence TI2000 60x40 2” Entry Horns, 15” Speaker Grilles
Four Eminence TI2000 2” entry 60x40 high frequency horns in very good condition. Two-piece ABS construction that allows a complex and accurate horn shape, while also making the flare very strong. Please note that the driver mounting flanges are slightly bowed—when the driver is bolted on to the horn, the flange straightens. This is common to all of the Eminence TI2000 horns and is not a defect. Three of the four in this sale are new, never mounted, and the fourth one shows slight screw marks on the mounting holes but is otherwise in as-new condition. Although my crappy photography makes it appear the horns vary in color, they are all uniformly black and just a little dusty and smudged from storage on a shelf. Dimensions: WxHxD 11.2" x 9.7" x 10.1" $160/set of four plus shipping.
Eight used heavy-duty 15” speaker grilles. Four of them are almost-new Dayton Audio HDSG-15 grilles, with very strong 1.2mm powder-coated steel. I think the four older ones are made by Penn Fabrication, but I’m not sure. The older grilles show some wear and tear: scratches, chips, scuffs, and some minor rust. One of them is missing the rubber ring that goes around the edge. The mounting clamps and hardware are not included. $45/set of eight plus shipping.
Images are of the actual items, which are located in SW Ohio. I ship only to addresses in the continental US. PayPal is okay. Best way to contact me is via email: mike dot smith at eventtechnicalsystems dot com.
Re: Eminence TI2000 60x40 2” Entry Horns, 15” Speaker Grilles
Still available. Prices reduced:
Four Eminence TI2000 2” entry 60x40 high frequency horns in very good condition. Two-piece ABS construction that allows a complex and accurate horn shape, while also making the flare very strong. Please note that the driver mounting flanges are slightly bowed—when the driver is bolted on to the horn, the flange straightens. This is common to all of the Eminence TI2000 horns and is not a defect. Three of the four in this sale are new, never mounted, and the fourth one shows slight screw marks on the mounting holes but is otherwise in as-new condition. Although my crappy photography makes it appear the horns vary in color, they are all uniformly black and just a little dusty and smudged from storage on a shelf. Dimensions: WxHxD 11.2" x 9.7" x 10.1" NOW $145/set of four plus shipping.
Eight used heavy-duty 15” speaker grilles. Four of them are almost-new Dayton Audio HDSG-15 grilles, with very strong 1.2mm powder-coated steel. I think the four older ones are made by Penn Fabrication, but I’m not sure. The older grilles show some wear and tear: scratches, chips, scuffs, and some minor rust. One of them is missing the rubber ring that goes around the edge. The mounting clamps and hardware are not included. NOW $35/set of eight plus shipping.
