EPM-6 Mixing desk. Troubleshooting bad audio for talk
Mike Turner
3
Hi guys, I am very much an amateur but will be setting up the audio for a talk at a community center on Wednesday. I am finding that one of the speakers isn't receiving the audio so well, to the point that the sound can only be faintly heard. I don't know what is causing this. The speakers are JBL G2/230. They both have a small red light labelled "mic" on the back. On one of them this lights up when plugged into the Soundcraft mixing desk, on the problem speaker it doesn't.
Anyway, I have tried plugging the mics into the desk via a shorter XLR to TRS cable into the "line" input. I also tried a very long XLR to XLR cable which I guess is at least 8 metres long. I'm not sure if this would reduce the signal from the mic or if the TRS to line cable is better?? The result is very similar regardless of the cable or which mic is used - It is still a fairly weak sound through one of the speakers. The strange thing is when an ipod or other music source is plugged into the mixing desk into the "2-track" inserts the speakers both work fine.
So my question is if I have a problem with one speaker what is the best way to deal with it at the desk? Would raising the input channel fader to a high level for the mic and keeping the master faders on the low side be the best way to avoid feedback and hissing sounds or would it be the other way round?? Also, would lowering the gain to the lowest possible level make a difference?
I have limited experience working with mixing desks so am panicking a little bit. I have made sure the settings on the back of the speakers are the same but can't think what else to try.
Re: EPM-6 Mixing desk. Troubleshooting bad audio for talk
The mic/line button needs to be pushed in on the speaker that has lower level. Alternatively, switch the OTHER speaker to line level and turn up the output of your mixer.
Hi Mike, I am 95% sure I pushed the mic/line button in but the mic light did not light up on the problem speaker. I will try again, but if it doesn't work I'll use your other suggestion. It's just good to get some ideas. Thanks.
Helo
Since 2-track with iPod works fine on both speakers, they are both fine and we can concentrate on what is going on in the mixer.
Leave your MASTER-faders like they are, when music from iPod plays good on both speakers - they should have effect on playback volume.
This is supposing you are using the XLR-outputs on your desk.
Connect your mic with XLR-cable - open GAIN to appr one-o-clock - set PAN to twelve-o-clock - open FADER carefully and listen.
Now you should have voice in both speakers.
Good luck and let us know...
Thanks guys, the sound for this event went really well. It turned out the mic button hadn't been pressed in on the speaker as I hadn't see the button. It is in a small recess and needs to be poked at with a pencil to click it in. I am hoping the speaker will be problem free for future events.
I had one person talking at the event who was holding the mic very far from his mouth. Maybe two feet away. This seemed to cause a faint but high pitch sound through the speakers, which I could not really control. I tried adjusting faders. Does anyone have tips for this apart from telling the person talking to hold the mic closer Can anything be done on the mixing desk?
The loudest sound at the mic wins, and if that happens to be the mic hearing itself via a loudspeaker, you get feedback. There are howls and squeals of all frequencies possible, some of which might be able to be knocked down enough with equalization (EQ), but you can only do so much.
Your thinking is correct: get that mic close to that mouth! :-)
