I had the pleasure of mixing on Tom Manchester's "S-Line" this past weekend. The "S-Line" is a medium format line array designed and built by Tom. I'll let him get into the details of the box, I'm just here to share my experiences with the boxes.
The set up was 3 boxes stacked per side, with my 6 single 18's center blocked.
The S-Line was powered with Crown MA3600's and a Lake for processing. 3 boxes per channel in this case.
The venue is the infamous St. Johns Hamilton in Baltimore. It's basically a 600 cap multipurpose gym. I've brought everything from Carvin TRx to EV QRx into this room. I've probably done over 100 shows in the room, so I know what to expect.
First impressions:
It's probably the loudest PA I've ever brought into this room. I had no issues hitting 108dBA+ at FOH(roughly 45' back). The boxes only need a little EQ in the mid range to smooth out, and just a little boost in the HF to add some sizzle. They reminded me of a Clair i3 in terms of SQ.
I'm not a fan of ground stacked line arrays, but since the array was so short, it really wasn't a big issue. Coverage was very smooth and consistent. I believe the boxes are 140 degrees horizontal, and it actually came in handy. I didn't need to use front fills. They covered all the way down front without a problem.
Come show time, we had just over 250 in attendance. Not quite a packed house, but it was enough to deaden the room and really see what the S-Line could do. The MF/HF section of these boxes is very impressive! There's plenty of output, and it stays clean up to limit. The low section runs out of gas first, and I feel like an extra Mid-bass box would be a big help, especially in shorter lines. I was mainly digging into the limiters with the snare and toms. Other than that, the boxes had plenty of output for a rock show, and I'd have no issues with SPL even with a packed house.
The boxes sound very good all around. Playback had a nice hi-fi sound. Again, I compare them to the Clair i3, as it's the LA box I have the most experience with, and I absolutely love it. I feel like a line of 6-8 of these would be good for a few thousand people. I'd have no issues if I came across these boxes in a venue. They're solid performers. Oh, and they're light too. Stacking them was quick and easy. The hardware is simple to work with, and goes together quickly.
Tom's got a solid box. He just needs to build more so I can really beat on them! :lol:
First impressions:
