Junior Varsity
EWI amp rack takes a beating
<blockquote data-quote="Greg Cameron" data-source="post: 2160" data-attributes="member: 42"><p>I'm fast to point out that the EWI stuff is generally not comparable to the heavy duty tour grade stuff, but I have to give them props in this case. My little venue hosted the Red Hot Chili Peppers last night and the stage was tight with extra gear since they brought in more Rat subs and L'Acoustic ARCs to supplement my Rat Sound house PA. They had to stack a couple more amp racks on top of my already ~300lb. EWI amp rack. That's about another 300 lbs stacked on top. I expected something to give, but it was not an issue. I wouldn't recommend this as regular practice, but it's good to know you can do it in a pinch.</p><p></p><p>Greg</p></blockquote><p></p>
[QUOTE="Greg Cameron, post: 2160, member: 42"] I'm fast to point out that the EWI stuff is generally not comparable to the heavy duty tour grade stuff, but I have to give them props in this case. My little venue hosted the Red Hot Chili Peppers last night and the stage was tight with extra gear since they brought in more Rat subs and L'Acoustic ARCs to supplement my Rat Sound house PA. They had to stack a couple more amp racks on top of my already ~300lb. EWI amp rack. That's about another 300 lbs stacked on top. I expected something to give, but it was not an issue. I wouldn't recommend this as regular practice, but it's good to know you can do it in a pinch. Greg [/QUOTE]
Junior Varsity
