Junior Varsity
Excursion question
<blockquote data-quote="Ben Lawrence" data-source="post: 3696" data-attributes="member: 391"><p>I have a few EV SXA250 speakers. One of them when set at the same level and fed the same input signal bottoms out on the 15" driver. You might have heard it before the ugly "snapping" sound. I pulled the grill and gave a quick push on the driver it doesnt seem to be rubbing or anything. What exactly is worn out? Does it just need a recone? At lower volumes it plays fine but at some point is extending further than its identical bredren.</p></blockquote><p></p>
[QUOTE="Ben Lawrence, post: 3696, member: 391"] I have a few EV SXA250 speakers. One of them when set at the same level and fed the same input signal bottoms out on the 15" driver. You might have heard it before the ugly "snapping" sound. I pulled the grill and gave a quick push on the driver it doesnt seem to be rubbing or anything. What exactly is worn out? Does it just need a recone? At lower volumes it plays fine but at some point is extending further than its identical bredren. [/QUOTE]
Junior Varsity
Excursion question
