Junior Varsity
First time Centre Subs
<blockquote data-quote="Justin Myers" data-source="post: 5457" data-attributes="member: 1274"><p>Hello,</p><p></p><p>I'm doing a gig next week where I want to try using 4 x centre subs with the 2 a side L/R subs. The 4 centre subs are not the same breed as the L/R subs and The L/R subs will have the mid/hi boxes on top of them.</p><p></p><p>The L/R subs are all run off 1 x IT8000. 2 of the centre subs are run off 1 x IT8000 and the other 2 run off 1 x IT5000. I was going to run the same mono auxilary sub signal to all amps.</p><p></p><p>I have never tried using centre subs before. This gig is outdoor and I have the room to put the subs out front. The stage is 36 foot and I have experimented with lots of different Mapp predictions and came up with this.(See Pic) It has 0 delay on the centre subs and the positioning seems to create a reasonable coverage. Well, reasonable compared to the other predictions I tried. </p><p></p><p>Any word of advice from the more experienced?</p><p></p><p>Thanks</p><p></p><p>Justin</p></blockquote><p></p>
[QUOTE="Justin Myers, post: 5457, member: 1274"] Hello, I'm doing a gig next week where I want to try using 4 x centre subs with the 2 a side L/R subs. The 4 centre subs are not the same breed as the L/R subs and The L/R subs will have the mid/hi boxes on top of them. The L/R subs are all run off 1 x IT8000. 2 of the centre subs are run off 1 x IT8000 and the other 2 run off 1 x IT5000. I was going to run the same mono auxilary sub signal to all amps. I have never tried using centre subs before. This gig is outdoor and I have the room to put the subs out front. The stage is 36 foot and I have experimented with lots of different Mapp predictions and came up with this.(See Pic) It has 0 delay on the centre subs and the positioning seems to create a reasonable coverage. Well, reasonable compared to the other predictions I tried. Any word of advice from the more experienced? Thanks Justin [/QUOTE]
Junior Varsity
