Hello all.
My company's standard "big box" PA these days is the HK Audio Projector.
Link:
Products - PROJECTOR - HK Audio Portable Sound
It's designed to typically be stacked on a stage riser or similar to make sure the high-mids reach the proper height. This is especially important due to the driver for the highs being situated in the middle of the top box. Please see "exploded view" picture attached.
Lately, we have sometimes used an empty flightcase between the subs and the high-mid box to elevate tha top box. This gives us the proper height but saves us the trouble of bringing risers just to elevate the stacks. I guess there possibly is a benefit from having the subs on the floor, as well. It also saves floor space.
First, I got the idea to build some custom cable boxes to fit perfectly and stable between the subs and the high-mids for a sleeker look and more stable stacking.
Then I got the idea to ramp it up one notch to make a front fill box of sorts:
On gigs where we use two stacks on either side of the stage we already implement a front fill solution. The splay opening between the stacks is just big enough for us to fit a small flightcase inbetween, with one of our standard wedges on top. The idea is to "brighten up" the sound somewhat for the people right in front of the stacks, especially when they are seated, but there are people standing further back so that we need to stack the PA pretty high.
Link to HK Audio DART wedge:
Products - D.A.R.T - HK Audio Portable Sound
This has put the wedge at about the same height as the top of the second sub and does seem to help intelligibility and such while being very close to the stack.
My idea would be to make cable boxes to double as "spacers", but here's the twist: There would be a front compartment housing a horn driver, possibly the same horn driver as the top end of the Projector box, as well as a small amp module with a simple crossover. The Projector system is active so power and signal is already present.
Please see my rough sketch that I have enclosed.
It would be great to get some people's opinion of the validity of this idea as well as any contributions to make this a viable project.
PS: The mid-to-high X-over frequency is 900Hz and the high end module of the Projector is rated at 300 watts. The specs say that the X-over is passive, but I guess that's a typo as the high-mid module does contain two amps with separate limiters, etc.
Best regards,
Kristian Johnsen
Link:
Best regards,
Kristian Johnsen
