Fulcrum DX1295 review
Silas Pradetto
Graduate Student
I haven't really talked about it on the forums much, but a few months ago I went through a 'downsizing' phase with the company, selling off the older, larger equipment in exchange for higher performance, newer equipment.
Looking at all the options, I needed something extremely hi-fi but yet extremely small, and also very loud. There weren't a lot of options that fit my criteria, until I saw speakers from the new Fulcrum Acoustic at last year's LAB get-together.
Even though there wasn't a very formal speaker demo, I think most people at the event noticed that the Fulcrum stuff was very loud and sounded very good. This stuck with me, and I later called them up to see about getting a demo.
Rich and Dave were extremely accommodating with getting me demo equipment, namely a pair of DX1565 and a pair of DX1295 set up as 'portable' units with pole mounts and handles. Just a note: these are install speakers, and for a couple extra bucks they add handles and the pole socket. I'm told that dedicated portable speakers are coming soon.
I set up all the mains I had left at the shop, which included a Community IHP1294, Community RS880 custom biamped, and one each of the Fulcrum boxes. Playing music through each in turn and together made it immediately obvious that the Fulcrum stuff sounded really good, and went really loud. The Community IHP also sounded very good, almost as good as the Fulcrums, but nowhere close to as loud. The RS880 was louder than either Fulcrum, but didn't sound nearly as good, and had some funky horn resonances to it, which were especially obvious in comparison to such good sounding speakers.
My goal was to replace the four RS880s and the IHPs with one or two pairs of something new. Both the DX1295 and DX1565 got close to as loud as the RS880; in fact, against my conservative limiters, the RS880 was the same continuous SPL as the DX series. Once the limiters were opened up a bit on the 880, it won by about 5dB.
It was clear that the DX series would do exactly what I wanted, and could replace all the other speakers I had without a problem. The only remaining question was which of the two DX series speakers would work better, or should I get one of the other configurations?
To expand on the design of the DX series, they are a bit of a different design that most other speakers on the market today. There is a coaxial woofer/HF driver on top that uses a passive crossover, plus another woofer below without a crossover. This creates two passbands, making the entire box biamped. Both woofers go all the way down, while the lower woofer is rolled off quite a bit lower than the upper woofer.
The boxes use Dave Gunness's new Temporal EQ, which does fancy things with FIR filters and yields nearly perfectly flat phase and magnitude response above 500Hz, which also results in a nearly perfect impulse response. There are two sets of presets provided by Fulcrum: Level 1 presets are used in processors and amplifiers which have the necessary FIR capability, and Level 2 presets are used where that FIR capability is lacking. Since I own Crown I-Tech HDs, I use Level 1 presets.
Additionally, since the crossover is locked out in the Itechs, Fulcrum provides high-passed and full-range presets. They can make custom high-pass presets for you, as you need. Rich is pretty much the DSP magician, so he will take care of whatever you want.
Listening to just the DX series side-by-side with the high-passed preset (stock 100Hz), the two models sound nearly identical. There was something about the 1565 that Adrian and I didn't like as much as the 1295, but we couldn't put our finger on it. Both boxes needed a tiny cut in the 3k range to make them sound more pleasant to our ears, but they were flat when measured without the cut.
Only when the boxes were run in full-range mode did the difference become extremely obvious: the dual-15 had a LOT more low-frequency capability. They were more than good enough to not need subs probably a lot of situations, but since I nearly always run LAB subs, it didn't really matter to me. When used in high-pass mode with LABs, the 1295 got every bit as loud as the 1565, and was our winner.
In fact, I bought the demo pair. Dave Gunness hand-built one of them, since it's the first one ever made. He's going to sign it for me one of these days.
I have now used the pair of DX1295s at a bunch of shows, from small, intimate venues to medium-size theatres (700 people) and more. As a testament to the sheer SPL they can produce, I just used the pair to cover 2,000 people in a gym for an event with a DJ playing hip-hop music and a couple MCs. While right at the edge, they did great. In that particular case, I had them on Global ST132s up pretty high and angled down a bit, with PRX612s as front fills. I don't think I have pictures of this since my 20D died at that show.
It takes every bit of four LAB subs to keep up with the two DX1295.
Using the DX series, it's literally like using studio monitors for every show. I almost never need EQ on the mains unless the room is really bad, and there is no feedback, even when running them behind the vocalists. I even did a panel discussion for 100 attorneys (pressure!) with four lavs, and no issue with feedback! The pattern is great, rated at 90 degrees but is quite pleasant even beyond that. The two woofers help keep vertical pattern much better than just a single woofer.
Oh yeah, and the DX1295s are 63 pounds each! I can sling around two at once with no problem. Paired with a K&M variable-angle tilters and the ST132s, I don't foresee any shows that I'm going to have a problem covering in the near future.
Here are links if you'd like to check things out further:
Fulcrum Acoustic home
DX1295
DX1565
I was not biased going into this demo or purchase, but now I'm absolutely biased that these speakers are the best things since IIR. Feel free to contact me for more information or a demo: [email protected]
Re: Fulcrum DX1295 review
It is rare that I can say something like this but the Fulcrum stuff, and especially the DX1295, are some of the best sounding and performing loudspeakers on the planet. Dave and co. are so clever you can hear it, and not only does the box sound amazing even at extreme SPL, it also behaves well off axis. Absolutely cutting edge.
I was at the Gearfest last year, and can't stop thinking about the Fulcrum boxes.
I haven't played with a lot of high end speakers, but the boxes at the Gearfest are the best
sounding speakers I've ever heard!
Would be nice to see the portable versions at Gearfest this year.
By the way, Rich and Dave were the highlight presenters last year.
Thanks, Don
Thanks for the excellent review, Silas. I cuncur with most everything here, especially the helpfulness of the Fulcrum Staff. They've all been helpful, and Rich has gone above and beyond the call of duty for me on at least 2 occasions.
For some brief moments I measured 127db at 1 meter (yes I was wearing earplugs) with the clip light barely flickering on a Yamaha P7000S amp on a single DX1295. That's as close to a manufacturers published spec (129db) that I've ever been able to verify, and I have little doubt that these speakers could reach 129db under more accurate test conditions.
A closer inspection of the phase response of the DX1295 reveals that it is relatively flat above 300hz, and if I recall, my own measurements revealed similar behavior.
While the sound is great, I hesitate to call it "studio monitor" quality. I played them side by side with my Urei 809's and preffered the 809's. For studio monitor quality, I'm told the new RM22 and RM25 are amazing. I may use them on an install when it makes sense to do so.
Grant
Hey Grant, I would still consider them to be near-studio monitor quality. The DX series uses the same drivers as the studio monitor boxes, but the studio monitor boxes are bigger and built using thicker/stronger wood (maybe MDF, I can't remember) to be more inert and offer better LF extension.
I've heard the studio monitors at the Fulcrum R&D shop. Quite impressive.
Last time I was there Dave and Rich told me they might be switching the LF section of the DX series to another woofer that sounds even better and handles more power, but has a bit lower sensitivity. I will have to hear the difference to see if it's worth upgrading mine, but I usually prefer higher sensitivity over pretty much any other option.
And, I haven't done any SPL measurements yet, but I am 100% sure the Fulcrums meet spec, since I can hit them with 2500 watts from the IT5000HD with no issue, they just keep sounding great. That would be almost 3dB over what you measured, so I think 129dB SPL continuous is actually a rather conservative number...
So, I just used four DX1565 at a large outdoor show this past weekend, and they did so well, I bought them too! I'll see about getting a picture on here; Dave and Rich came to the show and took pictures, but I didn't since my lens died.
Also note: no crowd showed up until the headliner came on.
attachment.php
Photo credit: Dave Gunness
+1
I've installed almost 100 of the smaller (single woofer) CX1295's and by far the most impressive feature is the smooth off-axis response.
Jason
