I have one too many of these sitting on the shelf, and-so this one is available for sale!
Offered is one (1) slightly used, very nice Furman PL-Plus Series II rack-mount power conditioner. Only a few light marks from handling and storage, etc. This model/series has been discontinued by Furman in the past couple of years. There is a rear-mounted connector for a BNC type Little-lite, not included but available for an additional $15, if desired.
The unit will be shipped in the original packaging.
Specifications
payment accepted via Paypal in US funds.
Specifications
- Current Rating: 15 amps
- Operating Voltage: 90 to 140 VAC
- Over Voltage Shutdown: 140 VAC typically
- Voltmeter Accuracy: ±2 VAC, calibrated with internal trimpot adjustments
- Spike Protection Modes: Line to neutral, zero ground leakage
- Spike Clamping Voltage: 188 VAC peak @ 3,000 Amps, 133 VAC RMS (tested to UL-1449 and USA / CIDA A-1-1, 6,000 VAC @ 3,000 Amps)
- Response Time: 1 nanosecond
- Maximum Surge Current: 6,500 amps
- Noise Attenuation: 10 dB @ 10 kHz, 40 dB @ 100 kHz, 100 dB @ 10 MHz
Linear attenuation curve from 0.05 - 100 Ohms line impedance - Dimensions: 1.75 H x 19 W x 10.5 inches
- Weight: 11 lbs (5 kg).
- Construction: Steel chassis, .125 inches brushed and black anodized aluminum front panel; glass epoxy printed circuit boards
- Power Consumption: 11 watts
- Safety Agency Listings: CE, NRTL-C
