Lighting & Electrical
Generator powered gigs...power question(s)
<blockquote data-quote="Rob Spence" data-source="post: 207915" data-attributes="member: 80"><p>Two inputs isnÂ’t going to work well. The distro would be seriously custom, expensive and complicated. </p><p></p><p>If you really want to use more than one generator rather than one of the correct size, it will be safer and much more economical to simply have a pair of simple L14-30 to multiple circuit distros. Just be sure to bond the grounds together. </p><p></p><p>Better would be a 50a 240v distro with a CS connector input. Pretty much all the diesel generators in the 25-45kva size you can rent have multiple CS outputs. </p><p></p><p>You could make a L14-30 to CS adapter to plug on a smaller generator when you need to.</p></blockquote><p></p>
[QUOTE="Rob Spence, post: 207915, member: 80"] Two inputs isnÂ’t going to work well. The distro would be seriously custom, expensive and complicated. If you really want to use more than one generator rather than one of the correct size, it will be safer and much more economical to simply have a pair of simple L14-30 to multiple circuit distros. Just be sure to bond the grounds together. Better would be a 50a 240v distro with a CS connector input. Pretty much all the diesel generators in the 25-45kva size you can rent have multiple CS outputs. You could make a L14-30 to CS adapter to plug on a smaller generator when you need to. [/QUOTE]
