Has anyone multi track recorded to the SD slots on the M32R?
Steve Pacholski
2
Acworth GA
The result i'm getting is a single .wav file with 32, 16 or 8 channels depending on the recorder settings and a .BIN file. When loaded into a DAW the track is silent, but has the correct time frame. Is there something I'm missing or is there a way to separate the channels?
Check your routing. Go to routing, then card output (if I recall correctly) and make sure the card is set to either local If your using a stage snake directly to the inputs on the 32 or AES50 A if you are using a stage box.
Also was a problem if you set it to 8 track, wouldn't record audio for some reason. I saw other people had that issue as well.
