Junior Varsity
Help me build an active setup to handle 400-500 indoors or 300-400 outdoors
<blockquote data-quote="Fernando Lopez" data-source="post: 1207" data-attributes="member: 193"><p>I want to have a medium sized active rig to handle up to 400-500</p><p></p><p></p><p>I currently have 4 RCF art905as subs and no tops for this task.</p><p></p><p>I really like these subs and their size and weight</p><p></p><p>But they cost the same as the RCF 4Pro8003 subs which are bigger, heavier but slam harder.</p><p></p><p>So I am debating between gettting 4 more art905as or getting 4 4Pro8003. With 8 equal subs I can use them all and have a big wall of subs. WIth 4 of the 4Pro I would get the same SPL but they are harder to move around and if stairs are in the way it would be really hard to move them. It is usually me and a roadie.</p><p></p><p>So that is question number 1</p><p></p><p>Now the next and last question would be my tops</p><p></p><p>I really like the rcf art722a, the downside is the 90 degree horizontal dispersion,as I would like 2 per side to handle the output of the subs. I also like the EV ZXA5-60 but I am not sure about a 15 inch top and a 15 inch sub. Although I have used this combination (4 ZX5 to 4 art905as) but the bass is lacking. </p><p></p><p></p><p>My small setup would be 2 tops and 4 subs and the big one 4 tops and (either 8 15 inch subs or 4 18 inch subs).* </p><p></p><p>I want to keep a uniform look</p><p></p><p>Other options:</p><p></p><p>JBL VRX918sp the cost for me is almost double the RCF or KW subs, same for the tops so they are a no go</p><p>QSC KW is also an option to consider 4 KW152 and 4 KW181</p><p>FBT is also expensive around here</p><p>Yorkville is hard to find here, but the ls801pb with ZXa5s on top is also an option</p><p></p><p>I am also open to other active suggestions/combos</p></blockquote><p></p>
[QUOTE="Fernando Lopez, post: 1207, member: 193"] I want to have a medium sized active rig to handle up to 400-500 I currently have 4 RCF art905as subs and no tops for this task. I really like these subs and their size and weight But they cost the same as the RCF 4Pro8003 subs which are bigger, heavier but slam harder. So I am debating between gettting 4 more art905as or getting 4 4Pro8003. With 8 equal subs I can use them all and have a big wall of subs. WIth 4 of the 4Pro I would get the same SPL but they are harder to move around and if stairs are in the way it would be really hard to move them. It is usually me and a roadie. So that is question number 1 Now the next and last question would be my tops I really like the rcf art722a, the downside is the 90 degree horizontal dispersion,as I would like 2 per side to handle the output of the subs. I also like the EV ZXA5-60 but I am not sure about a 15 inch top and a 15 inch sub. Although I have used this combination (4 ZX5 to 4 art905as) but the bass is lacking. My small setup would be 2 tops and 4 subs and the big one 4 tops and (either 8 15 inch subs or 4 18 inch subs).* I want to keep a uniform look Other options: JBL VRX918sp the cost for me is almost double the RCF or KW subs, same for the tops so they are a no go QSC KW is also an option to consider 4 KW152 and 4 KW181 FBT is also expensive around here Yorkville is hard to find here, but the ls801pb with ZXa5s on top is also an option I am also open to other active suggestions/combos [/QUOTE]
Junior Varsity
