Junior Varsity
How many watts is my sub getting
<blockquote data-quote="Fernando Lopez" data-source="post: 1061" data-attributes="member: 193"><p>I have a 4ohm TH-118</p><p></p><p>My amp is an EV CP4000S</p><p></p><p>specs: </p><p>Amplifier Gain 32 dB</p><p>Continuous Rated Power</p><p>(1 kHz, THD 1%) 2Ω 2100 Watts</p><p>Continuous Rated Power</p><p>(1 kHz, THD 1%) 4Ω 1500 Watts</p><p>Continuous Rated Power</p><p>(1 kHz, THD 1%) 8Ω 900 Watts</p><p>Continuous Rated Power</p><p>(20-20 kHz, THD<0,2%) 4Ω 1200 Watts</p><p>Continuous Rated Power</p><p>(20-20 kHz, THD<0,2%) 8Ω 600 Watts</p><p>Electronics Type Amplifier</p><p>Input Impedance (Balanced) 20 kΩ</p><p>Input Sensitivity +7dBu</p><p>Intermodulation Distortion (SMPTE) 0.02 %</p><p>Maximum Bridged Output 4Ω 4500 Watts</p><p>Maximum Bridged Output 8Ω 3000 Watts</p><p>Total Harmonic Distortion 0.05 %</p><p></p><p></p><p>Usually I will connect it to the bridge output, but sometimes due to low voltage I just plug it to the A channel</p><p></p><p>So my question is:</p><p></p><p>How many watts is my sub getting from the amp?</p><p></p><p></p><p>Thanks,</p></blockquote><p></p>
[QUOTE="Fernando Lopez, post: 1061, member: 193"] I have a 4ohm TH-118 My amp is an EV CP4000S specs: Amplifier Gain 32 dB Continuous Rated Power (1 kHz, THD 1%) 2Ω 2100 Watts Continuous Rated Power (1 kHz, THD 1%) 4Ω 1500 Watts Continuous Rated Power (1 kHz, THD 1%) 8Ω 900 Watts Continuous Rated Power (20-20 kHz, THD<0,2%) 4Ω 1200 Watts Continuous Rated Power (20-20 kHz, THD<0,2%) 8Ω 600 Watts Electronics Type Amplifier Input Impedance (Balanced) 20 kΩ Input Sensitivity +7dBu Intermodulation Distortion (SMPTE) 0.02 % Maximum Bridged Output 4Ω 4500 Watts Maximum Bridged Output 8Ω 3000 Watts Total Harmonic Distortion 0.05 % Usually I will connect it to the bridge output, but sometimes due to low voltage I just plug it to the A channel So my question is: How many watts is my sub getting from the amp? Thanks, [/QUOTE]
Junior Varsity
