Hello everyone,
I need to convert a voice recorder into ultrasound (over 20,000 hz) and then play it, and I was wondering if anyone here could guide me to achieved that.
The reason I want to do this:
I am currently practicing self-hypnosis to cure myself from some nasty stuff I am going through. Self hipnosis is a technique in which a person suggests things to his own subconscious mind, such as: "my body is healing and I will start feeling better".
Humans are not able to hear ultrasound, but according to some research, the subconscious mind can actually perceive ultrasound and suggestions played this way will have a greater effect.
I have googled a lot and the only thing I found is that a software called "Audacity" might do this, but before I get into this I though it was a good idea to ask some audio proffesional so I can have the big picture in all this.
Also: if I found a way to convert the voice recorder into ultrasound, how should I play the file?? will standard headphones do the job??
Thank you for your attention, any feedback is welcome.
Best regards
Best regards
