Re: I/O panel configuration
I've also downsized the racks in recent years. Most of my gigs are done with just one person, so the 250 lb., 15-space amp racks just had to go. Part of the problem was solved by going to powered subs (half the size of the previous ones), and the rest was facilitated by ditching the bi-amped monitors and mid-highs I had used since 1990, and going to higher power amplifiers running full range. I had a number of 6-space racks used for the bi-amped monitors, and those now have a pair of QSC PLX1804 amps in them, with some old TDM crossovers to highpass the racks used for mains (with the powered subs).
When I was buying the amps, the salesman tried to sell me on PLX2502s instead, but since I figured I would usually only load them at 8Ω, and only sometimes to 4Ω, I went with the lighter, cheaper, but higher voltage models. The 2502 wouldn't really have been much of a step up in power from the Carver PM1.5s I was replacing. The more shallow 1804s also allow the I/O panels to be mounted in the back of the 16" deep racks. Initially, I set them all up as 4-channel racks, with 4 pairs of male and female XLRs for the inputs, and 4 pairs of NL4s for the outputs, with pairs 1 and 3 carrying two channels from the amps. The monitors have been modified so that either channel can be picked up by the speaker, depending on which of the two input jacks you use. You can then loop to another box and have it on the same or other output of the amp.
That worked well, until I realized that I had more amp channels than speakers, and I started thinking about bridging some of the amps. QSC doesn't recommend bridging the '04 series, but running stereo with a 4Ω load is really no different than bridging into an 8Ω load, so I thought I'd give it a try. Instead of 600W available for each EV ZX3, I now have 1800W. So far, it sounds good, and nothing (speakers or amps) has blown up. The inputs of the amplifiers are fed from the HPF outputs with a Y-cable with the 2nd channel's polarity reversed.
The smaller panels below are for the main racks with the bridged amps. There is only one NL4 for each output since the minimum load is 8Ω. I staggered the NL4s to make it easier to get at the latch on the lower connector, and if I ever rethink things and want to go back to bi-amping, I might add another NL4 to each channel. The orange outlets are not wired for isolated ground, I just needed back wired outlets because of the extremely tight confines of a 3" wide box on the 2 RU panel.
GTD
