Looking for pro comps to be used as brickwall limiting for IEMs. I know dominators used to be king but it's been a while since I heard that. For those that want the additional safety of external limiters before the transmitter, what are you using?
Did you have problems in that area?Looking for pro comps to be used as brickwall limiting for IEMs. I know dominators used to be king but it's been a while since I heard that. For those that want the additional safety of external limiters before the transmitter, what are you using?
...... On my way I noticed the big difference between the Sennheiser IEM300 G2, G3 and IEM2000 (which is a great piece of gear).
Most significant: The 2000 have more headroom.Please elaborate on the differences.
Have you checked the overall latency for that setup? Would be interesting to know if the inserted Finalizer adds significant latency or not.I have a bunch of TC Finalizer 96K units for mix inserts. Originally we did this so we could take the iem rack and patch into any analog console on a fly-in or festival and start with a basic mix eq as well as limiting.
When the console switched to digital I kept them (inserted through AES i/o) so there would be a familiar starting point.
They have worked well.
In the digital setup...they are on AES i/o so no A/d and D/A conversion and they are clocked with the desk so there is no sample rate conversion happening either.
As well as the old PM5D -> Galileo issue, where SRC is applied by Meyer and raises the latency. In that case the overall latency is lowered by going analog in between.Don't assume this: The Rane DSPs that we (theater) use have (according to Rane) more latency digital-in to digital-out than analog-in to analog-out. Don't understand it myself.
