[FS] iLive R72 Mixer Case (or other similar size mixers)
Chris LaRocque
142
VT, USA
This is a new case but was stenciled (which has been removed). The case never hit the road and other than covering the stencil it is basically mint.
I ordered for an Allen & Heath iLive R72, but suspect other mixers will fit. The rack mount tray is removable.
Case Specifications:
ATA Case
Inside Dimensions: 23" x 20.25" x 9.25"
3/8 wood
Black ABS laminated
Plank Foam on sides and base
Aluminum tongue and groove
Large recessed spring loaded latches
Recessed handles with rubber grip (3 sides)
Steel Ball corners
SafeCase™ cases are covered with a Lifetime Warranty.
Asking $375.00 plus S&H.
