Junior Varsity
Impedance question on double 15 with a horn
<blockquote data-quote="Alan Sledzieski" data-source="post: 4306" data-attributes="member: 1022"><p>If you have a cabinet with a crossover, ( A Jbl 4733a in this case ) and the crossover is designed for a 4 ohm load on the 15's and a 16 ohm load on the horn, what will happen if you put a 8 ohm load on the horn part of the x over?</p><p></p><p> Basically I want to replace a 16 ohm jbl horn / driver with a different brand and its 8 ohm.</p><p></p><p>Thanks.</p></blockquote><p></p>
[QUOTE="Alan Sledzieski, post: 4306, member: 1022"] If you have a cabinet with a crossover, ( A Jbl 4733a in this case ) and the crossover is designed for a 4 ohm load on the 15's and a 16 ohm load on the horn, what will happen if you put a 8 ohm load on the horn part of the x over? Basically I want to replace a 16 ohm jbl horn / driver with a different brand and its 8 ohm. Thanks. [/QUOTE]
Junior Varsity
