Inexpensive MADI sound card
In the UK at least, the SSL cards are the cheapest followed by the UB Madi. Bear in mind though that the UB Madi only sees the first 48 available inputs and is not patch able making it not a full solution, especially with something like a venue which doesn't have fully patch able outputs...
Sent from my Nexus 7 2
I would never buy an opti-coax from ssl, very unreliable in my experience. In fact, I believe that the latest run of ssl Madi converters/routers will be manufactured by directout who make fantastic gear
Re: Inexpensive MADI sound card
Is the CAT5 MADI that Digico uses compatible with the CAT5 MADI that Soundcraft uses? Will the Digico boxes work to connect a Soundcraft Vi1 via MADI to a laptop (with a RME MADI card)
regards,
Philippe
