Installs
Insert cable from balanced Aux-output?
<blockquote data-quote="Robin Jacobsson" data-source="post: 6724" data-attributes="member: 3853"><p>Hi, we just ordered Behringer X32 that will probably arrive next week.</p><p>I will order cables so we can install it properly when it arrives, and I have a question regarding the Aux-output.</p><p></p><p>I will use another Behringer Rack-mixer's phones output for In-ear monitoring, so I have to send the signal from the X32 > Rack mixer.</p><p>Since it's balanced outputs, should I use a insert-cable to connect it to ch 1-2 (L/R) in the Rack-mixer or should I just connect them with a TS cable - Aux out > Line in 1 (L) ?</p><p></p><p>Thank you!</p></blockquote><p></p>
[QUOTE="Robin Jacobsson, post: 6724, member: 3853"] Hi, we just ordered Behringer X32 that will probably arrive next week. I will order cables so we can install it properly when it arrives, and I have a question regarding the Aux-output. I will use another Behringer Rack-mixer's phones output for In-ear monitoring, so I have to send the signal from the X32 > Rack mixer. Since it's balanced outputs, should I use a insert-cable to connect it to ch 1-2 (L/R) in the Rack-mixer or should I just connect them with a TS cable - Aux out > Line in 1 (L) ? Thank you! [/QUOTE]
Installs
