Junior Varsity
Itech question / help...info..
<blockquote data-quote="Vinny D&#039;Agostino" data-source="post: 2341" data-attributes="member: 112"><p>I am setting up my new to me IT8k.</p><p>Using S.A. I set up all my limiters (Peak Voltage & RMS ) and I checked & double checked and everything appears to be correct....</p><p>Then, when I disconnect my computer from the amp I went and scrolled through the menu screen on the amplifier and I can see all of my settings in there.</p><p>But...There is a screen that appears that says *Clip Limitters* On / Off.</p><p>They are set to *OFF*....Should they be set to *ON*???</p><p>Why don't I see this in S.A., or am I missing something??</p><p></p><p>I have not checked my original IT8K that I had Bennett setup for me...I just used the same system settings he came up with when he helped set my rig up.</p><p></p><p>Any info would be great.</p><p>Thanks</p><p></p><p></p><p>Vinny</p></blockquote><p></p>
[QUOTE="Vinny D'Agostino, post: 2341, member: 112"] I am setting up my new to me IT8k. Using S.A. I set up all my limiters (Peak Voltage & RMS ) and I checked & double checked and everything appears to be correct.... Then, when I disconnect my computer from the amp I went and scrolled through the menu screen on the amplifier and I can see all of my settings in there. But...There is a screen that appears that says *Clip Limitters* On / Off. They are set to *OFF*....Should they be set to *ON*??? Why don't I see this in S.A., or am I missing something?? I have not checked my original IT8K that I had Bennett setup for me...I just used the same system settings he came up with when he helped set my rig up. Any info would be great. Thanks Vinny [/QUOTE]
Junior Varsity
