Junior Varsity
JBL STX Problem
<blockquote data-quote="Kevin Spencer" data-source="post: 7889" data-attributes="member: 4767"><p>I just added 2 JBL STX 828s cabs to my inventory. Running them each on a crown XTi 6002 however output isn't right. When I have everything rigged, The tops work perfectly as usual, however the subs are inaudible in comparison (I have SRX 828 cabs too so I know how loud they should be). My signal chain is clean, crossover settings are spot on, etc. Ive tried everything. I'm powering it at 4200 watts program but the mixer level clips before i even get anywhere close to full volume, or even half volume for that matter. Is it that the signal strength is decaying? I have no idea what is wrong.</p></blockquote><p></p>
[QUOTE="Kevin Spencer, post: 7889, member: 4767"] I just added 2 JBL STX 828s cabs to my inventory. Running them each on a crown XTi 6002 however output isn't right. When I have everything rigged, The tops work perfectly as usual, however the subs are inaudible in comparison (I have SRX 828 cabs too so I know how loud they should be). My signal chain is clean, crossover settings are spot on, etc. Ive tried everything. I'm powering it at 4200 watts program but the mixer level clips before i even get anywhere close to full volume, or even half volume for that matter. Is it that the signal strength is decaying? I have no idea what is wrong. [/QUOTE]
Junior Varsity
JBL STX Problem
