Sine-wave power AND a nice hand-warmer for those outdoor October gigs in MN....
Nice! Send one to me too, please.
How loud do you have to crank the volume for those UltraPhones to keep your ears warm?
Just wondering why you got the 3000 rather than 2 2000s you could parallel if you need to? The 2000 is more scalable and easier to carry if you need less than 1600 watts for small gigs.
Dick,
How do you feel about the noise level of the 3000 versus the 2000? I've experience with the 2000 and found it to be a solid little unit, but the 3000 seems to be a big step up in every regard. There's no significant difference in their rated noise output, but the 3000 seems to spread its noise out over the frequency spectrum better based on recordings off Honda's website.
Dave,
You may be interested in this review ScreenLight & Grip's E-Newsletter of the EU6500, which is apparently the bee's knees. This is God's gift to generator reviews and use writeups.
Great Article Bennett!
I'm wanting to get into the 6500 and a 2K, fully outfit the 6.5 with the transformer / distro they package. Wan to buy my 3K? I've started it the first of each month for about a year, but that's it. Help me get into that big boy unit.
A lot of these small gasoline engines easily develop varnish in the carburetor if you use ethanol-containing gas that is not real fresh. Apparently the ethanol picks up water vapor from the air and unless you drain the bowl in the carburetor and run the engine dry after each use, letting it sit with gas in it can cause the carburetor to gunk up with a layer of varnish that then has to be manually cleaned out, a PITA job at best.
Anyone know if any of the 4 models EU2000i, EU3000i, EU3000is or EU6500is is less prone than the others to developing varnish in the carburetor from gas that is not real fresh? If you don't use the generator more than a few times a year, it is a pain to repeatedly have to refill your gas can every few months with fresh gas, add stabilizer, and toss the old gas (eg, run it in your car).
I would love to, but it won't fit in my current apartment! If you still have it in a year maybe.Great Article Bennett!
Yamaha also has a nice line of quiet inverter generators. I have a 3000 watt unit that I've only used a few times but really like so far. Yamaha Generators, Portable Generator, Generators for home
Jeff
